disable SSL on captive portal
  • 1.  disable SSL on captive portal
    Posted Nov 14, 2016 02:13 PM
    Have IAP setup to use Captive portal with 802.1x. Macs are getting cert errors. Want to diable SSL for captive portal access. Where is that setting?
    currently getting: https://securelogin.arubanetworks.com:4343/swarm.cgi
    want to use http://securelogin.arubanetworks.com/cgi-bin/login only.
    Thxs
  • 2.  RE: disable SSL on captive portal
    Posted Nov 15, 2016 11:12 PM
    anyone?
