Disable Stateful SIP Processing in 8.x
  • 1.  Disable Stateful SIP Processing in 8.x
    Posted Apr 11, 2018 07:33 PM
    In 6.4, I was able to use the "firewall disable-stateful-sip-processing" and similar commands for sips and sccp. The commands don't appear available on the MM in 8.x. Does anyone know how to disable those features?
    #AirheadsMobile
  • 2.  RE: Disable Stateful SIP Processing in 8.x
  • 3.  RE: Disable Stateful SIP Processing in 8.x
    Posted Apr 12, 2018 04:39 PM
    Yes I see it in the documentation, but the options aren't actually there in the GUI or CLI.
  • 4.  RE: Disable Stateful SIP Processing in 8.x
    Posted Apr 12, 2018 05:29 PM
    The instructions in the link I posted say where you can find the stateful firewall options.
  • 5.  RE: Disable Stateful SIP Processing in 8.x
    Posted Apr 12, 2018 05:54 PM
    Looking at the stateful firewall options on the GUI and the commandline, I cannot find that option.
    Why would you want to disable it?
  • 6.  RE: Disable Stateful SIP Processing in 8.x
    Posted Apr 12, 2018 06:28 PM
    We had issues with soft UC endpoints dropping voice packets over the RAP during a call. The fix was to disable the stateful ALG for those services.
    #AirheadsMobile
  • 7.  RE: Disable Stateful SIP Processing in 8.x
    Posted Apr 12, 2018 08:29 PM
    Okay.  Checking on that discrepancy.
  • 8.  RE: Disable Stateful SIP Processing in 8.x
    Posted Apr 12, 2018 08:32 PM
    Found it - looks like it was moved under the UCC settings and can only be done at the Mobility Master level (get error otherwise):
