Cloud Managed Networks
Disable Switch Port Interface from Aruba Central Cloud
This thread has been viewed 31 times
  • 1.  Disable Switch Port Interface from Aruba Central Cloud
    Posted Jul 29, 2021 11:53 AM
    Hi Team,
    I am new to managing switches with Aruba Central and cannot find the option for disabling switchports. The 2930F is managed in a group with a template assigned. This is in Sync.
    Any advice would be welcome.
    Matthew McDonald
  • 2.  RE: Disable Switch Port Interface from Aruba Central Cloud
    Posted Dec 03, 2021 10:25 AM
    Hi Matthew,
    did you ever get an answer or find out ?
    I would like to know how to enable a port again if it did get disable by loop-protect feature and a manual action is required to get the port enabled again.
    The config should not differ (between template and switch-running) - and I guess as switch is managed by Central it's not possible to do via CLI directly.
    Groetjes
    Jochem
    Jochem Knoben
  • 3.  RE: Disable Switch Port Interface from Aruba Central Cloud
    Posted Dec 04, 2021 02:55 AM
    You can do it from switch cli via ssh or from Central Console feature.
    Go into config mode and enable aruba-central support mode:
    # configure terminal
    (config)# aruba-central support-mode enable
    After you finish just disable support-mode
    (config)# aruba-central support-mode disable
    Best, Gorazd
    Gorazd Kikelj
  • 4.  RE: Disable Switch Port Interface from Aruba Central Cloud
    Posted Dec 06, 2021 02:41 AM
    Thanx Gorazd,
    I hope Aruba will add some different possibility to do so in the future.
    Groetjes
    Jochem
    Jochem Knoben
