Airwave doesn't have telnet enabled, and SSH is already enabled. Don't think you can enable telnet, nor you can disable SSH.
You can very that by attempting to telnet to Airwave (should not work) and attempt SSH (expected to work).
Original Message:
Sent: Jul 18, 2024 07:28 AM
Subject: Disable Telnet and Enable SSH on Airwave
As per compliance requirement customer wants to disable telnet and enable SSH on Airwave AMP-8.3.0.1-x86_64.ova and need verification commands that telnet is disabled and SSH is enabled. Appreciate your support on the same
