Become a Member
Hi,I am seeing a possible brute force attack from Chinese IP's on my router with repeated telnet attempts using root/admin usernames. I would like to disable telnet entirely, is it possible on this MSR930 model? Sorry, I am a bit new to router configuration but can login to router via ssh.
You should be able to disable the MSR930 Telnet Server service entirely (permitted than you're still able to connect via SSH and Console) by issuing the command:
[Sysname] undo telnet server enable
once in system-view mode.
