last person joined: 5 hours ago
Disable TLS1.0 in Aruba IAP-315?
  • 1.  Disable TLS1.0 in Aruba IAP-315?
    Posted Oct 31, 2018 10:55 AM
    We've just set up a few IAP-315 here.
    Now our monitoring system complains that it accepts TLS1.0.
    How do I disable that it should present this?
    The only reply I can find about this is from 2014, and it says it's not supported at the time, but now it's 4 years later, and I surely hopes it's now a feature.
  • 2.  RE: Disable TLS1.0 in Aruba IAP-315?
    Posted Oct 31, 2018 11:17 AM
    Ok, so I got a bit further already. I found this link: IAP tls version to choose
    And the controller accepts the commands, so I tried setting
    • config
    • web-server
    • ssl-protocol tlsv1_2
    • end
    • commit apply
    And that works, but it doesn't work with tlsv1_1??
    So for now all is good.
