Network Management
Disable U-APSD on controller to prevent Iphone from sleep mode and disconnect
  • 1.  Disable U-APSD on controller to prevent Iphone from sleep mode and disconnect
    Posted Jan 12, 2017 03:05 AM
    i am using controller 3600 with aruba os 6.4.4.1
    Iphone is going into sleep mode when is locked and wi fi is disconnected
    how can i disable power save mode ( u-apsd ) to prevent iphone from going intp this mode
  • 2.  RE: Disable U-APSD on controller to prevent Iphone from sleep mode and disconnect
    Posted Jan 12, 2017 04:16 AM
    Whether a phone "sleeps" or not is a function of the phone and its applications.  U-APSD might not be the solution to your problem.  What are the symptoms and what is the application?
  • 3.  RE: Disable U-APSD on controller to prevent Iphone from sleep mode and disconnect
    Posted May 17, 2017 06:42 AM
    I have the same problem exactly with the same contoller 3600 and software version at my place of work, Even tough the iphone 7 do not disconnect when locked at home with 3Com router.
    When i made debugg it showed the client disassociate then reassociate with every lock or sleep from the phone.
    Please need to know what option exactly in the controller so i can keep the iphone connected all the time and do not miss any notifications.
  • 4.  RE: Disable U-APSD on controller to prevent Iphone from sleep mode and disconnect
    Posted Jul 04, 2017 08:44 AM
    Is it an open SSID without Encryption? Apple Devices automatically disconnect from that SSID to prevent MITM Attacks during lock screen.
