Comware
Disable Vendor ID as suggested by KB5009543
This thread has been viewed 16 times
  • 1.  Disable Vendor ID as suggested by KB5009543
    Posted Jan 14, 2022 02:01 AM
    HPE Comware Software, Version 7.1.064, Release 0821P11
    We are using IPSec with L2TP.
    Microsoft have suggest to disable Vendor ID for IPSec VPN January 11, 2022-KB5009543 (OS Builds 19042.1466, 19043.1466, and 19044.1466)
    Microsoft remove preview
    UPDATED 01/11/22 REMINDER Windows 10, version 2004 reached end of servicing on December 14, 2021. To continue receiving security and quality updates, Microsoft recommends that you update to the latest version of Windows 10. To update to one of the newer versions of Windows 10, we recommend that you use the appropriate Enablement Package KB (EKB).
    View this on Microsoft >
    Is it possibility to disable Vendor ID with Comware 7?
    Matti Jaatinen
  • 2.  RE: Disable Vendor ID as suggested by KB5009543
    Posted Jan 14, 2022 02:43 AM
    Hi Matti,
    MSR routers running Comware 7 don't seem to have such feature.
    If your VPN connections from Windows 10 clients with KB5009566 and KB5009543 updates installed have been affected, uninstallation of abovementioned patches should help to recover L2TP and IPSec connections.
    Ivan Bondar
  • 3.  RE: Disable Vendor ID as suggested by KB5009543
    Posted Feb 01, 2022 04:35 AM
    Thank you for the reply, My Query has been solved.
    Target Pay and Benefits
    James Gross
  • 4.  RE: Disable Vendor ID as suggested by KB5009543
    Posted Jan 31, 2022 02:31 PM
    Disabling the Stelnet service. Disable the Stelnet service when it is not required. The SSH service port number is easy to be found by a scanning attacker.
    James Gross
  • 5.  RE: Disable Vendor ID as suggested by KB5009543
    Posted Feb 01, 2022 01:03 AM
    "Disabling the Stelnet service. Disable the Stelnet service when it is not required. The SSH service port number is easy to be found by a scanning attacker."
    - How this would be helping?
    https://downloadcdn.h3c.com/en/201907/10/20190710_4368721_99-book_1211734_1285_0.pdf
    Matti Jaatinen
