disable watchdog on iap 105
  • 1.  disable watchdog on iap 105
    Posted Jul 01, 2013 03:54 AM
    I would like to use my iap105 for a site survey. So no uplink availble.
    Is there any option to do this?
    It seems that the watchdog process is disturbing my plan :-)
    I tryed to fool the iap with a loopback, no luck so far.
    the only option with succes is to add a modem to the eth port, but that uses a lot of power from my site survey battery!
    thanks for any help
  • 2.  RE: disable watchdog on iap 105
    Posted Jul 01, 2013 08:16 AM
    You should be able to put the IAP into standalone mode (under the Convert section) and then in the latest ArubaOS you just need to enable the 'bring up with no uplink' option under the SSID settings.
    I find setting a static IP for the IAP also helps as the AP boots quicker because it doesn't have to time out DHCP requests.
    David
  • 3.  RE: disable watchdog on iap 105
    Posted Jul 03, 2013 04:06 AM
    Found the option! Thanks, but....
    I m running 6.2.1.0-3.3.0.0_38115
    and as soon as i boot my standalone iap, (so disconnect the uplink wire) it would NOT let me connect.
    The leds: pwr-green, enet-x, 11a/n, green and 11b/g/n-red
    as the uplink cable is plugged in, it would let connect me. Also the 11b/g/n led is green (as is the enet)
    So there is proberly some other option which is configured, witch expect a uplink cable....
    Any suggeestions? I can send a boot log if it thats helpfull.
    thanks
    regards, Jeroen
  • 4.  RE: disable watchdog on iap 105
    Posted Jul 03, 2013 10:00 AM
    Can you verify you have the option "Can be used without uplink" option set?  This is done on a per-SSID basis.  Also check that your SSID is set to "All Bands".
    Also, how are your clients getting an IP address?  Have you set the DHCP assignment to "Virtual Controller Assigned"?
  • 5.  RE: disable watchdog on iap 105
    Posted Jul 04, 2013 06:05 AM
    well I checked above, and all are set as mentioned!
    With a console cable connected, i can watch the boot proces, and maybe that will help by finding the solution...
    booting looks okay until:
    Writing 4
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    wifi uplink not present...
    do ethtool autoneg on for bond0
    Ethernet uplink not active yet
    No uplink active. Becoming Mesh Point
    AP xml model 39, num_radios 2 (jiffies 27913)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    election init: rand=18 HZ=500
    setting bond0 as bridge child
    setting gre0 as split child
    notify asap_mod 3g no present...
    Starting watchdog process...
    Compressing all files in the /etc/httpd directory...
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    NTP Server not saved in flash... using default
    and a bit later:
    AP rebooted Sat Jan 1 00:12:15 UTC 2000; mesh link BAD. rebooting mesh point by sapd
    shutting down watchdog process (nanny will restart it)...
    How come it is still checking for a uplink?
    any suggestions?
  • 6.  RE: disable watchdog on iap 105
    Posted Jul 08, 2013 01:14 AM
    I just tried on an IAP-105 running v. 3.3.0.2 and it works for me.
    While wired I created a new SSID, checked the box to allow the SSID without an uplink, set the SSID to get an IP from the VC, open network.   I then converted to Standalone mode and rebooted.  While it was starting to reboot I disconnected the Ethernet cable.  Upon boot the 5GHz and 2.4GHz LEDs came up and the new SSID was advertising.
    From the logs it looks like your IAP was still trying to use the wire. I am able to see this behavior if only if I * do not * convert it to "Stand Alone" mode.  Since it could not find the network on the wire the expected behavior is to try to find the network via Mesh -- which it could not do.  Perhaps your IAP did not properly convert to Standalone.
    I would suggest resetting back to default and giving it another try.  If that does not work you should open a case with TAC for troubleshooting.
  • 7.  RE: disable watchdog on iap 105
    Posted Jul 08, 2013 01:59 AM
    Well....
    This is exactly what I did. and it works!
    The first time, I converted the iap to standalone mode, but left the cable in the iap.
    thanks for the help.
    Does anyone know if there is a option to see in what modes the iap is running at a particulair moment?
    regards,
    Jeroen
