we want to install some APs (AP105) at a school.
We need the possibility to disable/enable the wifi-interface of the ap.
Does somebody know any solution to do this.
One could be to put the ap on/off by connecting/disconnecting the power cord or something like this.
Is there an other possibility to do this?
The ap should only work if it is needed during the lesson, because of the radiation.
There are no specific times when it is needed.
Bye
