Disabling access to WebUI
  • 1.  Disabling access to WebUI
    Posted Mar 07, 2013 06:11 PM
    Is there a way to disable access to the WebUI on the controller? I don't want anyone to be able to try to log in through the public address... only on the private.
  • 2.  RE: Disabling access to WebUI
    Posted Mar 08, 2013 04:08 AM
    A simple way is to create a firewall policy which denies this kind of traffic and applying it to the interface (you can do this on Configuration - Port menu).
  • 3.  RE: Disabling access to WebUI
    Posted Mar 08, 2013 04:33 AM
    The post here:  http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-Connect-your-Aruba-Controller-to-a-Cable-Modem/td-p/951 shows you how to create an access list to lock down that port:  http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-Connect-your-Aruba-Controller-to-a-Cable-Modem/td-p/951
    Of course, you need to be careful when you are configuring an ACL on traffic that you are managing the controller from.
