last person joined: 4 hours ago
Disabling AP without rebooting
  • 1.  Disabling AP without rebooting
    Posted 22 days ago
    Hello Kind Sirs,
    Is there a way to disable an AP from broadcasting without moving it back to 'default' or another AP group?
    I need a quick test where we can disable an AP and quickly re-enable it without rebooting.
    Appreciate your input.
    Alex
  • 2.  RE: Disabling AP without rebooting
    Posted 22 days ago
    Two ways you can do this on AOS 8.
    Method 1.
    Use the "ap-name <ap-name>" configuration in CLI to add an "exclude-virtual-ap <profile>" AP name override to disable the target VAP. Remove the override when you want to enable the VAP.
    Method 2.
    Add the AP to a new group without the target VAP added to the group.
    Use the "ap-name <ap-name>" configuration in CLI to add ("virtual-ap <profile>") and remove the VAP ("no virtual-ap <profile>") at the device level.
