Disabling CPSEC on AP group
  • 1.  Disabling CPSEC on AP group
    Posted Mar 09, 2012 05:21 AM
    On my controller I have 2 different types of connected APs.
    1. APS with 802.1x ssid in bridge mode
    2. Mesh portal/points with guest portal in tunnel mode
    In the OS I am using when I tried to put the APS in group 1 to bridge mode I got a warning that I had to enable cpsec to do so. As this is a global command also the mesh APS in group 2 are forced to do cpsec.
    Question 1: I am using only internal lan links here so I don't want to use cpsec at all. Is there a way to use bridge ssids without cpsec ?
    Question 2: Can I disable CPSEC on the mesh AP group  to save bandwidth on the mesh link ?
    regards
    Oliver
  • 2.  RE: Disabling CPSEC on AP group
    Posted Mar 09, 2012 06:10 AM
    CPSEC is global, so if you enable it, it will enable it for all devices.  Enabling CPSEC can can cause your APs to be down for at least a few minutes while they get certificates, but when you do, it is done.  Make sure auto cert provisioning is on.
    You can make a Virtual AP bridged or an ethernet port bridged by provisioning an access point as a Remote AP, without turning on CPSEC.
    Turning on CPSEC does not save bandwidth on mesh links.
  • 3.  RE: Disabling CPSEC on AP group
    Posted Dec 03, 2018 05:21 AM
    what command to disable cpsec in cli ?
