Disabling HTTP fromt he administration
This thread has been viewed 16 times
  • 1.  Disabling HTTP fromt he administration
    Posted Oct 04, 2013 07:18 PM
    Is there a way to disable HTTP from the administration of the Wireless controller?
    I mean if you put the ip of the wirelesss controller yeah it will autredirect to the https
    But i would like to that when you type in http://wcip   it just doesnt work... and force you to do manually  https://wcip:4343
    Cheers
    Carlos
  • 2.  RE: Disabling HTTP fromt he administration
    Posted Oct 04, 2013 08:26 PM
    Put an acl on the physical management interface denying port 80 traffic to the management ip address, as a session ACL.
  • 3.  RE: Disabling HTTP fromt he administration
    Posted Oct 04, 2013 09:52 PM
    Ah so i have to use the firewall? i though it was something like with the swithces which you do something like aaa authentication https or something like that..
    Anyhways i tried that and when i try putting the policy to the interface i get this error
    GigabitEthernet 1/8:Invalid Access List Usage
    my rule looks like this
    ip access-list session Nohttp
      any   alias controller svc-http  deny
      any any any  permit
     I whent to the interface to apply this rule on "in" option
    What im doing wrong?
    Cheers
    Carlos
  • 4.  RE: Disabling HTTP fromt he administration
    Posted Oct 05, 2013 04:57 AM
    I apologize.  Make the ACL blocking http traffic to the controller's management port and allowing everything else:
    ip access-list session block-http
      any host 192.168.1.3 svc-http  deny
      any any any  permit
     Then, apply it as a session ACL to the controller's uplink port as a session ACL
    config t
    interface gigabitethernet "1/0"
    interface gigabitethernet "1/0" ip access-group "block-http" session
     Try to access the controller's management interface on http via that uplink port.  You should not be able to.  After that you can monitor the "hits" to that ACL:
    (192.168.1.3) #       show acl hits
    Port Based Session ACL
    Policy      Src  Dst          Service   Action  Dest/Opcode  New Hits  Total Hits  Index  Ipv4/Ipv6
    validuser   any  any          any       permit               0         488         7727   ipv4
    block-http  any  192.168.1.3  svc-http  deny                 3         8           8449   ipv4
    block-http  any  any          any       permit               59        200         8450   ipv4
    This of course will only work for traffic that is traversing that uplink.  If you have wireless users who's traffic terminates on that controller, it does not traverse that link, so you would have to block their traffic via user role.
  • 5.  RE: Disabling HTTP fromt he administration
    Posted Oct 05, 2013 11:23 PM
    Thanks Colllin that worked....
    Another thing....
    IF i got another interface vlan like for the guest access... well i do have to block that one too for http access...
    Does this would bother the captive portal?
    I bealive it wont because it will redirect it to the https://controlerip:8080 right?
    Where i am i cannot test that :(
    But i can remotely configure and test for the https access... what i cannot test is the captive portal.... but i would like to know that
    Cheers
    Carlos
  • 6.  RE: Disabling HTTP fromt he administration
    Posted Oct 06, 2013 12:04 AM
    The Captive Portal ACL already forwards all port 80 traffic to the 8081 captive portal. This is active in "logon" roles. You do not need to do anything in that role.
    When the user has already authenticated, you need an ACL in that role that blocks traffic from the ip address of the controller via http.
  • 7.  RE: Disabling HTTP fromt he administration
    Posted Oct 06, 2013 03:20 AM
    So what i need to do is to add that firewall policy that you gave me to all the authenticated roles im using  right?
    The one i just put on, just would work for non wireless users as far i understand
    Cheers
    Carlos
  • 8.  RE: Disabling HTTP fromt he administration
    Posted Oct 06, 2013 07:11 AM
    You are correct.
  • 9.  RE: Disabling HTTP fromt he administration
    Posted Oct 06, 2013 01:47 PM
    Thank you very much Collin!
