Wired Intelligent Edge
Disabling interface on Aruba 5400R / 3810M does not turn off PoE
  • 1.  Disabling interface on Aruba 5400R / 3810M does not turn off PoE
    Posted Mar 22, 2018 12:18 PM
    I've noticed when I disable an interface witht the "interface A1 disable" command on a 5400R / 3810M that PoE power is still provided to the device unless you type the  "no interface <PORTS> power-over-ethernet".
    Is this the correct behavior? Kind of a pain to have to type two commands to bounce a port.
  • 2.  RE: Disabling interface on Aruba 5400R / 3810M does not turn off PoE
    Posted Mar 22, 2018 01:59 PM
    Greetings!
    This is currently the expected (if not necessarily intended) behavior when an interface is disabled in the switch console.  I will pass your feedback along to our engineering team.
  • 3.  RE: Disabling interface on Aruba 5400R / 3810M does not turn off PoE
    Posted Mar 29, 2018 01:04 PM
    You dont have to type two commands. When you turn off POE the port goes down as the devices shuts down effectively boucing the port. Just a gotcha if you are not familiar with it.
  • 4.  RE: Disabling interface on Aruba 5400R / 3810M does not turn off PoE
    Posted Mar 29, 2018 02:26 PM
    I don't agree with that. Often we don't know if there is a phone or just a PC behind a port. What you suggested would only work for a device that needs PoE. You must do both if you don't want to spend the time figuring out what is on the port. Please correct me if this is wrong.
  • 5.  RE: Disabling interface on Aruba 5400R / 3810M does not turn off PoE
    Posted Mar 29, 2018 02:46 PM
    I see where you are coming from. I initially thought just about POE devices as that was the initial subject of the post. Other vendors diable the port and disable POE with the shutdown command whereas Aruba/HPE you either disable the port or disable POE. I believe it truly depends what you are attempting to accomplish. Do you want to bounce the port or reboot the device through the removal of power.
  • 6.  RE: Disabling interface on Aruba 5400R / 3810M does not turn off PoE
    Posted Mar 29, 2018 02:48 PM
    Exactly, guess I'm just stuck in my old ways because this and lack of a "default interface" command sre driving me crazy :-)
