Is there a way to disable IPv6 on RAPs? A customer is using the RAPs behind a DualStack Lite and is receiving log messages at the controller.
The logging level is set to warning.
rdnssd[1138]: 0: 2a02:128:3:5::1 expires at 1993300
no ideas?
There is no way to disable ipv6 on a RAP. There is not much ipv6 traffic there, though.
The problem is that the RDNSSD log message is flooding the controller log.
What version of ArubaOS is this? You should open a case with TAC so that they can determine why this is happening with your setup.
The version is 6.4.4.10 on a 3200XM
It is a cosmetic message that is fixed in 6.5.0.0 (bug 125997). The message should only show up when debugging is configured. Unfortunately it was not backported to 6.4.4.x.
Thank you! This is really bad, because 6.5 isn't supported for the 3200XM afaik
Opened a case to check if this bug will be fixed in 6.4.4.x.
Thank you!
