Disabling legacy client devices
  • 1.  Disabling legacy client devices
    Posted Sep 18, 2015 01:37 PM
    In IAP225, I would like to block legacy clients connecting to the SSID's. The arubas document suggests to use 'legacy-mode' command to control the legacy clients. As per the document, all non 802.11n devices are considered as 'legacy devices'. The document description is as given below.
    legacy-mode - Enables the IAPs to run the radio in non-802.11n mode.
    According to the above description, when disabled, any 802.11 a/b/g devices should NOT be able to connect to the network however it does not seem working. Please have a look at the below logs:
      IAP225# show radio config
      2.4 GHz:
      Legacy Mode:disable
      Single Chain Legacy:disable
      Beacon Interval:100
      802.11d/802.11h:enable
      Interference Immunity Level:2
      Channel Switch Announcement Count:0
      MAX Distance:600
      Channel Reuse Type:disable
      Channel Reuse Threshold:0
      Background Spectrum Monitor:disable
      Max Tx Power:0
      Min Tx Power:0
      5.0 GHz:
      Legacy Mode:disable
      Beacon Interval:90
      MAX Distance:600
      Standalone Spectrum Band:5ghz-upper
      Max Tx Power:0
      Min Tx Power:0
      IAP225#
    Connected Clients:
    IAP225# show ap association
    The phy column shows client's operational capabilities for current association
    Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client V: 802.11v BSS trans capable
    PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz; t: turbo-rates (256-QAM)
                 VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
                 <n>ss: <n> spatial streams
    Association Table
    Name               bssid              mac                auth  assoc  aid  l-int  essid          vlan-id  tunnel-id  phy              assoc. time  num assoc  Flags  DataReady
    18:64:72:c8:51:56  18:64:72:05:15:72  cc:fa:00:a9:12:9a  y     y      1    10     Q_streaming_1  4092     0x0        a-VHT-20sgi-1ss  1m:30s       1          W      Yes (Implicit)
    18:64:72:c8:51:56  18:64:72:05:15:72  c8:f9:f9:34:13:8e  y     y      2    12457  Q_streaming_1  4092     0x0        a                52s          1                 Yes (Implicit)
    18:64:72:c8:51:56  18:64:72:05:15:63  5c:50:15:24:f0:21  y     y      2    12457  Q_streaming_2  4092     0x0        g                1m:16s       1                 Yes (Implicit)
    18:64:72:c8:51:56  18:64:72:05:15:63  18:af:61:68:e0:f8  y     y      1    20     Q_streaming_2  4092     0x0        g-HT-20sgi-1ss   20s          1          WK     Yes (Implicit)
    Num Clients:4
    IAP225#
    Question: Is 802.11b device only considered as legacy device[a/g are not]? It could be  a case that information  documents is not correct. Need clarification on this.
            or
    controlling the legacy devices functionality not working in IAP225?
    Please let me know.
    Shiva
  • 2.  RE: Disabling legacy client devices
    Posted Sep 18, 2015 04:40 PM
    You cannot currently disallow 11a and 11g clients from associating. You can however remove the data and basic rates under 12 to stop 11b clients from associating.
  • 3.  RE: Disabling legacy client devices
    Posted Sep 18, 2015 07:21 PM
    Thank you for your quick response. I will change the data rate and test again.
    Shiva
