Hi everyone,
I have been experiencing HPE switches only few months and I'm struggling with displaying log issue.
I'm sure this issue wouldn't be hard to solve but hard to find the information.
One of my customer uses a "NTP server" for the HPE switches and requested me disabling the specific log as below.
%Mar 17 01:38:57:694 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 5 to 4 after clock update.
%Mar 17 02:53:34:452 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 4 to 5 after clock update.
%Mar 17 03:10:40:437 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 5 to 4 after clock update.
%Mar 17 03:53:32:531 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 4 to 5 after clock update.
%Mar 17 04:23:31:539 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 5 to 4 after clock update.
%Mar 17 06:14:34:595 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 4 to 5 after clock update.
%Mar 17 06:31:39:600 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 5 to 4 after clock update.
%Mar 17 06:48:45:613 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 4 to 5 after clock update.
%Mar 17 07:05:49:609 2017 L2_6F_02 NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 5 to 4 after clock update.
The above syslog is seems synchronizing the time and I've searching from the manual but I'm not sure about this is the command to disable the above log.
The command that I found is as following. "ntp-service in-interface disable".
Also, It's not possible to have a test, because I can only visit this customers' site once in every months for maintenance.
Please share if you had experienced above or similar issue.
Thank you in advance.
#stratum#NTP
