disabling redirect in 3s, 2s, 1s
  • 1.  disabling redirect in 3s, 2s, 1s
    Posted Mar 05, 2013 03:49 PM
    anyone know if you can disable this timeout? with an internal splash page ok, but with an external one i don't also want to see the AP.
  • 2.  RE: disabling redirect in 3s, 2s, 1s
    MVP EXPERT
    Posted Mar 05, 2013 03:55 PM
    Try adjusting the Redirect Pause located under the Captive Portal Authentication Profile, setting it to 0 should solve this.
    Edit - sorry didn't realise this was for an Instant :)
  • 3.  RE: disabling redirect in 3s, 2s, 1s
    Posted Mar 05, 2013 03:57 PM
    i don't believe i have a captive portal auth profile on an instant AP :smileyvery-happy:
  • 4.  RE: disabling redirect in 3s, 2s, 1s
    yes, sorry about that, realized it was in the Instant thread......
  • 5.  RE: disabling redirect in 3s, 2s, 1s
    MVP EXPERT
    Posted Mar 05, 2013 04:00 PM
    I'm not sure if it's even possible, I can't find an option for it!?!
  • 6.  RE: disabling redirect in 3s, 2s, 1s
    Posted Mar 05, 2013 04:03 PM
    same here, but perhaps im overlooking something.
  • 7.  RE: disabling redirect in 3s, 2s, 1s
    Posted Mar 05, 2013 03:56 PM
    Deleted......
