Disabling spanning tree on 7210 Controllers
  • 1.  Disabling spanning tree on 7210 Controllers
    Posted May 31, 2018 09:06 AM
    We have two controllers (MODEL: Aruba7210), Version 6.5.4.2.
    The core network that they are connected to is using MSTP. As the controllers only support RSTP and PVST, I think it may be best to disable spanning tree onthe controllers and let the core switches handle loop prevention via MSTP.
    I would like to know the following:
    1 - Is it possible to disable spanning tree entirely on the controllers - if so how?
    2 - With spanning tree disabled, will the controllers forward BPDUs received on one port out of the other(s), or will they be dropped.
    Thanks in advance,
    Jon
  • 2.  RE: Disabling spanning tree on 7210 Controllers
    Posted May 31, 2018 09:23 AM
    config t
    no spanning-tree
    https://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/spanning-tree(Global).htm?Highlight=spanning%20tree
    That will turn it off globally and depend on your switches for loop detection.  This is typically a best practice.
  • 3.  RE: Disabling spanning tree on 7210 Controllers
    Posted May 31, 2018 09:32 AM
    Thanks for the quick answer to question 1.
    I would still like to understand what the behaviour of the controller will be with spanning tree disabled. Will MSTP BPDUs coming in to a port on the controller be forwarded out of other ports, or will they be dropped?
  • 4.  RE: Disabling spanning tree on 7210 Controllers
    Posted May 31, 2018 09:41 AM
    It will be forwarded out of ports on the same VLAN.
