last person joined: 3 hours ago
Disconnect a client from central?
  • 1.  Disconnect a client from central?
    Posted Oct 17, 2016 10:30 AM
    I was looking at Central with clients connected and I couldn't see where you can disconnect a client. Can someone please point out where I can do this in Central?
    Also how do you change the group password?
    Thank You
    Joseph
  • 2.  RE: Disconnect a client from central?
  • 3.  RE: Disconnect a client from central?
    Posted Oct 17, 2016 10:55 AM
    Thank you. That was easy. How about changing the password to the group that you create?
  • 4.  RE: Disconnect a client from central?
    Posted Oct 17, 2016 11:00 AM
    Which password?
  • 5.  RE: Disconnect a client from central?
    Posted Oct 17, 2016 11:03 AM
    Hi When you create a new group in Central it asks for a password to setup. The default does this too when you create your account. So if I had two groups
    1. Miami
    2. California
    Each has a password. How do you change this.
