Disconnect the clients after some time
  • 1.  Disconnect the clients after some time
    Posted Feb 13, 2018 11:01 AM
    we have a cluster of Aruba IAP-305, with an employee SSID, with WPA2-Personal.
    The customer asks to disconnect the clients after some time that they are connected, a kind of maximum time of connection.
    Is it possible to do it with Aruba Instant?
    Thanks.
    Kind regards!
  • 2.  RE: Disconnect the clients after some time
    Posted Feb 13, 2018 11:47 AM
    If you use WPA2-PSK, and you had a wa to disconnect clients,  the supplicant on the client will just reconnect the user with the preshared key.
  • 3.  RE: Disconnect the clients after some time
    Posted Feb 14, 2018 02:10 AM
    Is it possible to do it, using other authenticantion methods or using a guest SSID ?
    Thanks.
    Kind regards.
  • 4.  RE: Disconnect the clients after some time
    Posted Feb 14, 2018 05:54 AM
    You would need an external AAA server like clearpass to do that, typically with radius accounting and a database that keeps track of how long a user has been connected.
  • 5.  RE: Disconnect the clients after some time
