Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
  • 1.  Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 22, 2017 11:13 AM
    we just installed a cluster with 9 IAP-305 and 2 IAP-103.
    Our customer have issues using apple devices, mainly Iphone 7 and Iphone 6. The devices tend to disconnect and are unable to reconnect to the wireless network autonomously. The customer need to disconnect and reconnect manually the divice. The wireless network has wpa2 Personal authentication and external Dhcp and it's configured to use the default vlan. The devices has the same problem in both, 2,4 Ghz and 5 Ghz. With the Android phone I didn't had the same problems.
    Thanks.
    Best regards.
    Michele
  • 2.  RE: Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 22, 2017 11:30 AM
    - How many SSIDs are you broadcasting?
    - Do you have "Broadcast filter ARP" enabled on all your SSIDs in the "advanced" setting.
    - Under RF> ARM, what is your Minimum and Maximum transmit power?
  • 3.  RE: Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 22, 2017 12:14 PM
    Hi Joseph,
    -we are broadcasting only one ssid.
    -The broadcast filter is disabled, because we had problem to discover and use a printer connecter to the wireless network.
    - Min power: 12 - Max power: Maximum
  • 4.  RE: Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 23, 2017 07:20 AM
    @Michele wrote:
    Hi Joseph,
    Make the min and max power 12 to start.  If that does not work, turn on Broadcast Filter ARP, and make sure Airgroup and MDNS and DLNA are enabled.  You would be able to find the printer and have broadcast filtering enabled, when Airgroup MDNS and DLNA are enabled.
  • 5.  RE: Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 24, 2017 06:25 AM
    I solved the issue activating the protocols 802.11.r and 802.11.k.
    Now apple devices are roaming correctly under all the APs.
    Is it normal that Apple devices, such as iphone and ipad, doesn't roam if that protocols are disabled?
    Thanks for your advice
    Michele
  • 6.  RE: Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 24, 2017 07:00 AM
    Activating 802.11r and 802.11k are typically risky, because not all clients leverage them completely or properly.  Very few deployments even have 802.11r and 802.11k enabled and things work just fine.  Enabling r and k might just be masking another issue.
    UPDATE 6/2018 -  The updated RF and Roaming Optimization Validated Reference Design Guide (VRD) has been published and has updated recommendations about enabling 802.11v, k and r in user networks.  The VRD can be found here: http://community.arubanetworks.com/t5/Validated-Reference-Design/RF-and-Roaming-Optimization-for-Aruba-802-11ac-Networks/ta-p/432994
  • 7.  RE: Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 30, 2017 06:28 AM
    We removed some rogue and interfering AP. After that also the Apple devices started to work fine also without the 802.11r and 802.11k.
    So probably it was in interference problem.
  • 8.  RE: Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 22, 2017 03:27 PM
    what InstantOS version r u using ? can u check if the devices failing in WPA key exchange ? ( Show log... ) Can u please disable client match and see if you notice any difference.
    #AirheadsMobile
  • 9.  RE: Disconnection issues with IAP-305 and IAP-103 running Firmware version 6.5.1.0-4.3.1
    Posted Mar 23, 2017 04:24 AM
    The firmware version is 6.5.1.0-4.3.1.2
    The device aren't failing in wpa key exchange.
    I tried to disable client match, but I don't notice any difference, the issue persist.
    thanks
