Disconnect/remove RAP device
  • 1.  Disconnect/remove RAP device
    Posted Oct 07, 2014 02:35 PM
    I have a hypothetical question regarding an Aruba 3200 Mobility controller and a RAP 3 or 5. If a user has been provided with a RAP3 for internal access and they leave the company, is there a way to disable or remove that RAP from the network.  I have looked at the controller GUI but I do not see any way to disable a RAP unit.
  • 2.  RE: Disconnect/remove RAP device
    Posted Oct 07, 2014 02:40 PM
    Remove the RAP from the whitelist under AP Installation.
  • 3.  RE: Disconnect/remove RAP device
    Posted Oct 07, 2014 02:57 PM
    I had a feeling it would be something simple.  Thanks!  That worked for me!
  • 4.  RE: Disconnect/remove RAP device
    Posted Oct 07, 2014 02:58 PM
    One last thing. Are you using Aruba Activate or whitelisting them manually?
