Disconnects with reason: Sapcp Ageout (internal ageout)
This thread has been viewed 35 times
  • 1.  Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 04:58 AM
    we have a client that is connecting to a RAP3, he never had issues, but now he has a new laptop with a new WLAN card (intel(R) Dual Band Wireless-AC 8260) and he is losing his connection constantly with following reason:
    (wlan_controller) #show ap client trail-info a4:34:d9:d5:d2:a2
    Client Trail Info
    MAC                BSSID              ESSID         AP-name      VLAN  Deauth Reason                    Alert
    a4:34:d9:d5:d2:a2  18:64:72:7c:04:31  Test1  rap-x  3  Sapcp Ageout (internal ageout)   Sapcp Ageout (internal ageout)
    Deauth Reason
    Reason                           Timestamp
    Sapcp Ageout (internal ageout)   Apr 11 10:40:38
    Sapcp Ageout (internal ageout)   Apr 11 10:40:17
    Sapcp Ageout (internal ageout)   Apr 11 10:39:49
    Sapcp Ageout (internal ageout)   Apr 11 10:39:40
    Sapcp Ageout (internal ageout)   Apr 11 10:38:40
    Sapcp Ageout (internal ageout)   Apr 11 10:38:21
    Sapcp Ageout (internal ageout)   Apr 11 10:37:36
    Sapcp Ageout (internal ageout)   Apr 11 10:36:54
    Sapcp Ageout (internal ageout)   Apr 11 10:36:34
    Sapcp Ageout (internal ageout)   Apr 11 10:36:16
    Num Deauths:10
    Alerts
    Reason                           Timestamp
    Num Alerts:10
    Mobility Trail
    BSSID              ESSID         AP-name      Timestamp
    18:64:72:7c:04:31  Test1  rap-x  Apr 11 10:40:41
    18:64:72:7c:04:31  Test1  rap-x  Apr 11 10:40:38
    18:64:72:7c:04:31  Test1  rap-x Apr 11 10:40:17
    18:64:72:7c:04:31  Test1  rap-x  Apr 11 10:39:49
    Num Mobility Trails:10
    You can see these disconnections are very often.
    Anyone that saw this type of disconnections before? "Sapcp Ageout (internal ageout)"  ? What does it mean?
    Kind regards,
  • 2.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 08:56 AM
    Is this an IAP or Controller-Based AP?  What version of ArubaOS or Instant OS?
  • 3.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 08:59 AM
    This one is configured as Remote Access Point controlled by a controller; Release 6.4.4.1 (will be upgraded to 6.4.3.7 tomorrow evening; 6.4.4.1 was a test from a former colleague, but I want to go back to a GA release)
    Kind regards,
  • 4.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 10:19 AM
    Internal Ageout is when the controller ages a device out, but does not send a deauth.  It is typically done because of inactivity.  What authentication/encryption is this device using?
  • 5.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 10:22 AM
    Like you can see, it is doing it a few times per minute, so the client shouldn't be inactive.
    802.1x authentication with WPA2-AES encryption
  • 6.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 10:33 AM
    What are the settings for your SSID profile?  Do you have handoff-assist configured?
  • 7.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 10:43 AM
    Hand-off assist is disabled
    SSID settings: pretty much default settings for our RAPs
    Other client (standing next to each other)  is working fine.
    Difference is that the new client is WIN10 and with an AC wlan card.
  • 8.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 10:45 AM
    Please open a TAC case, so that they can look at the specifics of your situation.
  • 9.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted Apr 11, 2016 10:46 AM
    I thought already that I would need to do that :-) Thanks anyway!
  • 10.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted May 02, 2017 07:18 AM
    Hi, i know this is a very old thread but i am having similiar issue.
    there is any update on how the case progress and the fix? thanks in advance.
  • 11.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted May 02, 2017 07:45 AM
    upgraded the controller to the latest, I think at that time the issue for the client was resolved in 6.4.4.10
  • 12.  RE: Disconnects with reason: Sapcp Ageout (internal ageout)
    Posted May 02, 2017 08:07 AM
    thanks Thomas.
