Original Message:
Sent: Aug 09, 2024 12:14 AM
Subject: Display AP Hostname in Beacon
I'm assuming there's a little bit of overhead when displaying AP hostnames. Do you know if it would be very service impacting in a somewhat dense deployment?
Original Message:
Sent: Feb 27, 2023 01:48 PM
Yes you can create a temp ssid-profile for this.
In my template I always include this command to make sure the AP name is always broadcasted.
If you create a temp profile you need to make make changes like a nieuwe Virtual AP profile. The easiest way is to enable the ap-name in the existing profile. Maybe schedule this outside off business hours if you want to be careful.
Willem Bargeman
Original Message:
Sent: Feb 27, 2023 01:31 PM
Thank you, William. I can see this option in the ssid-profile. Unfortunately, that would require making a regional change as this config comes from further up the node-hierarchy. I suppose we could create a temp wlan ssid-profile for the onsite survey. Either way, I wanted to follow up to confirm this. I keep trying to give you kudos but every time I try I have to log in and get taken out of the discussion.
Original Message:
Sent: 2/24/2023 3:10:00 PM
Subject: RE: Display AP Hostname in Beacon
Thank you! I will give this a try!
Original Message:
Sent: 2/23/2023 10:50:00 AM
Yes!!
wlan ssid-profile <profile-name>
advertise-ap-name
William Bargeman
Systems Engineer Aruba
Original Message:
Sent: Feb 22, 2023 05:14 PM
Hi Ayman,
Is this feature also available in ArubaOS 8.x for CAPs?
Thanks!
Original Message:
Sent: Aug 26, 2020 07:05 AM
You can do this from CLI on IAP.
Under wlan ssid profile you can configure "advertise-ap-name"
![ayman_mukaddam_0-1598439916868.png ayman_mukaddam_0-1598439916868.png](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/a6447b2f1f37476780ed21255de261ee_b84bc0da7b5e4a919301e7068f98c708)
