I've been tasked with finding the power usage on our switches. The problem is, when I try the display power command, it returns with nothing
Slot 1:
PowerID State Mode Current(A) Voltage(V) Power(W)
1 Normal AC -- -- --
2 Fault DC -- -- --
Slot 2:
2 Fault DC -- -- --
Although the DC shows a fault, there doesn't seem to be an actual fault.
The switch type is:
HPE 5130 48G PoE+ 4SFP+
The software version is:
System image: flash:/5130ei-cmw710-system-r3506.bin
System image version: 7.1.070, Release 3506
#voltage#watts#displaypower#5130#usage#comware#Power
