I have a couple of IAPs connecting via HTTPS to my Airwave server, but I only see their "internal LAN IP addresses" like 192.168.2.110. Those IAPs are getting NATed in a router, but after all they terminate with their public IP at the Airwave IP and the NMS should see / know the public IP.
I tried to find a way, but wasn't successful so far. I'd be glad if you could answer or point me to the resource that documents that.
If this is not possible at all, it would be interesting to know if you plan to implement such a functionality.
Otherwise I'd like to set the "location" of the AP/Virtual Controller, but I didn't find a way to do that. It would be nice just to be able to apply a certain "location label" on the IAP cluster.
Benny
