Distributed DHCP Scopes - Distributed, L2
  • 1.  Distributed DHCP Scopes - Distributed, L2
    Posted Jan 10, 2014 03:29 AM
    Hi all,
    I have a question about the configuration of DHCP Scopes (type Distributed, L2). In the documentation for the field Netmask there is this explanation:
    If Distributed, L2 is selected for type of DHCP scope, specify the subnet mask. The subnet mask and the network determine the size of subnet.
    ...but, where is the Network field?!
    Massimo
  • 2.  RE: Distributed DHCP Scopes - Distributed, L2
    Posted Jan 10, 2014 07:52 AM
    ip dhcp HOME-L2
     server-type Distributed,L2
     server-vlan 2
     ip-range 192.168.2.2 192.168.2.100
     subnet-mask 255.255.255.0
     reserve first 1
     lease-time 1800
     default-router 192.168.2.1
     dns-server 192.168.1.103
     domain-name elmontro.local
     client-count 20
  • 3.  RE: Distributed DHCP Scopes - Distributed, L2
    Posted Jan 10, 2014 08:03 AM
    Ok, this is quite misleading for me.
    Thank you very much for the comprehensive response Victor!
  • 4.  RE: Distributed DHCP Scopes - Distributed, L2
    Posted Jan 10, 2014 08:39 AM
    Is there a reason you need L2 DIstributed?  Please consider L3 Distributed.  It is our preferred method unless clients need to be on the same broadcast domain.
  • 5.  RE: Distributed DHCP Scopes - Distributed, L2
    Posted Jan 10, 2014 08:00 AM
