Distributed L3 DHCP scope Issues
  • 1.  Distributed L3 DHCP scope Issues
    Posted May 25, 2016 08:21 AM
    I am trying to setup an VPN from IAP cluster that terminates on to a mobility controller. From what I read, Aruba recommends a distributed l3 dhcp scope with the virtual controller being the gateway and the DHCP server. However, for some reason I cannot get the IAP-VCto assign addresses when I configure a distributed l3 DHCP scope.
    Here are the steps I have been taken:
    Afterwords I try to connect to the SSID and cannot DHCP an address. From the IAP cluster I can ping the networks on the Controller thorugh the VPN.
    Any thoughts?
  • 2.  RE: Distributed L3 DHCP scope Issues
    Posted May 25, 2016 09:19 AM
    Did you add the IAP MAC address to the controller RAP whitelist ?
    Is the MAC address added to the IAP trusted list ?
    Can you see the IAP when you run the "show IAP table" command ?
    Can you please share how did you configured your scope?
    Get Outlook for iOS
  • 3.  RE: Distributed L3 DHCP scope Issues
    Posted May 26, 2016 07:46 AM
    Victor,
    Thanks for the reply.
    It turns out that the IAP was not in the iap trusted db and only in the whitelist rap db.
    Thanks for your help!
