Wired Intelligent Edge
Distributed trunking on 5406
  • 1.  Distributed trunking on 5406
    Posted Jun 11, 2015 03:55 AM
    i have to set up DT between 2 5406zl and one 5308. I read the documentation of the last version K15.16 but some point are not clear.
    From doc :
    for the keepalive link STP must be disable, what about the ISC link as the customer run RSTP on all ports/all switchs ?
    From doc:
    I understand i have to create a Vlan and IP address with /30 for the keepalive link and it's writing
    "the ISC link must have a vlan interface configure for the same vlan on both DT switches"
    Does i need to create another Vlan for the ISC link ?
    I try to search configuration example and every time i don't see Vlan for ISC link, for example :
    SWITCH-A:
    trunk E4 trk99 lacp
    trunk E1 trk100 dt-lacp
    switch-interconnect trk99
    vlan 4092
    name "LACP-heartbeat"
    untagged A20
    ip address 192.168.92.5 255.255.255.252
    exit
    distributed-trunking peer-keepalive vlan 4092
    distributed-trunking peer-keepalive destination 192.168.92.6
    SWITCH-B:
    trunk E4 trk99 lacp
    vlan 4092
    untagged A20
    ip address 192.168.92.6 255.255.255.252
    exit
    distributed-trunking peer-keepalive destination 192.168.92.5
    Thks for your help !
    Brgds
    #distributedtrunking
    #VLAN
    #configuration
