Do AP need to be manually reset if Controller firmware upgraded?
  • 1.  Do AP need to be manually reset if Controller firmware upgraded?
    Posted Dec 03, 2020 07:30 AM
    I want to perform a firmware upgrade of mobility controller from OS6 to OS8, do I need to manually go to each AP to reset it in order it to get the latest firmware or the AP will automatically grab the latest firmware from an upgraded controller?
    regards
    Michael
    mic
  • 2.  RE: Do AP need to be manually reset if Controller firmware upgraded?
    Posted Dec 03, 2020 10:20 AM
    AP Firmware comes from the Controller.
    Be aware the AOS6 to AOS8 Upgrade is a kind of migration not placing AOS8 Image on Partition and reboot with new Image. Like the process going from 6.4 to 6.5 for instance.
    Best would to contact your local Aruba representitive.
