Do DRT files work on Aruba Instant?
  • 1.  Do DRT files work on Aruba Instant?
    Posted Jun 30, 2017 05:35 PM
    Hi guys,
    I've used DRT files on a controller but I'm trying to upload a DRT file on an Instant controller but no luck so far, I've no idea if even these files work on Instant, maybe they just work for controllers. Checking the release notes I can only found the procedure to upload files on a controller but nothing on Instant.
    Any thoughts?
    Best regards,
  • 2.  RE: Do DRT files work on Aruba Instant?
    Posted Jun 30, 2017 05:38 PM
    They do not. You have to upgrade the instant firmware to obtain the updated regulatory info...
  • 3.  RE: Do DRT files work on Aruba Instant?
    Posted Jun 30, 2017 05:48 PM
    Thanks for the quick reply.
  • 4.  RE: Do DRT files work on Aruba Instant?
    Posted Jun 30, 2017 06:34 PM
    To be clear, theDRT supported is in the release notes for every Instant firmware download.  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Command/Core_Download/Default.aspx?EntryId=25166
  • 5.  RE: Do DRT files work on Aruba Instant?
    Posted Jun 30, 2017 06:39 PM
    Awesome, thanks again!
  • 6.  RE: Do DRT files work on Aruba Instant?
    Posted Jun 30, 2017 06:57 PM
    One additional comment: starting with Instant version 8.3, DRT files will be supported there as well.
