Do Iap-105 AP's have ClientMatch available? What is the process to configure?
  • 1.  Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 25, 2015 10:47 AM
    We have 30 IAP-105's in our plant. There is a sticky device issue where a model PB50 Intermec printer won't roam.
    Does the model 105 have ClientMatch available? If so, how is it turned on and configured?
    Thanks in advance for the assistance.
    Bob
  • 2.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 25, 2015 10:53 AM
    Yes it is supported but whether it is available or not will depend on the version IAP OS .
    ClientMatch is also enabled by default
    What version are you running?
    It is under the RF tab
  • 3.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 25, 2015 11:16 AM
    Thank you for the quick response!
    IOS is version 6.3.1.8-4.0.0.9_47220
    Under RF, ClientMatch was disabled. I enabled it and will test shortly.
    Also I noticed that our other 2 settings are different than yours. Should we change them.
    I'll only change the ClientMatch for now.
    they are Band Steering = Disabled
    Airtime Fairness mode = Fair Access.
  • 4.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 25, 2015 03:53 PM
    Greetings,
    I enabled Client Match under the RF tab.
    When I go under support and run the "client match live" command, I get a message that client match is disabled and scanning notconfigured.
    Have I missed something?
    thank you.
  • 5.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 25, 2015 08:10 PM
    Try running the following command:
  • 6.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 26, 2015 10:08 AM
    Greetings,
    the "Status" command is not available. There is an "AP Client Match Live" command, so I ran that.
    Results are:
    Thank you for your assistance.
  • 7.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 26, 2015 10:35 AM
    This may be an issue with the code you are running , you should consider opening a TAC case or upgrading to a later code
  • 8.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 30, 2015 10:15 AM
    Dear Victor, thank you, may have to do that. when we first found this problem, I used the Maintenance --> "Check for new version" option and it did upgrade the Firmware image by one version. To 6.3.1.8.4.0.0.9_47220. That did not address the roaming device problem.
  • 9.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 30, 2015 12:59 PM
    you might also want to consider what your minimum and maximum transmit power is set to for ARM. If it's too high devices will not roam properly either. Best to start at min 12 and max 18.
  • 10.  RE: Do Iap-105 AP's have ClientMatch available? What is the process to configure?
    Posted Mar 30, 2015 03:08 PM
    Will do. Thanks for the tip.
