Do IAPs support downloadable roles ?
  • 1.  Do IAPs support downloadable roles ?
    Posted Feb 24, 2016 10:56 AM
    Do IAPs support downloadable roles from Clearpass? I can get this option to work on the controller, however when I setup role-based access on the IAP with a deafult role and then Aruba-CPPM-role, I only get the default role.
    Also the IAP is being managed by Airwave with the ICG engine.
  • 2.  RE: Do IAPs support downloadable roles ?
    Posted Feb 24, 2016 11:15 AM
    Is not supported yet, You need to define the user-roles in the Instant environment and then return the user-role using the enforcement-profile = Aruba-User-Role = <YOUR-USER-ROLE>
  • 3.  RE: Do IAPs support downloadable roles ?
    Posted Feb 24, 2016 11:20 AM
    Thanks. I figured as much. Just thought I would check.
    Sent from my iPhone
