Wired Intelligent Edge
Do two stacked 2930M pass VLANS without connecting them from the front side?
  • 1.  Do two stacked 2930M pass VLANS without connecting them from the front side?
    Posted Mar 04, 2019 10:20 AM
    Hi Guys,
    I have 2 x 2930M switches which should be redundant; the 4 SFP ports of each switch are fully used for uplinks to edge switches
    In case we used a stacking module, should I have to connect both switches with the copper prorts and do trunking again for the VLANS to pass between the 2 switches or is there any protocol that will enable this without reconnecting the switches?
    #2930M
    #2930M
  • 2.  RE: Do two stacked 2930M pass VLANS without connecting them from the front side?
    Posted Mar 06, 2019 10:12 PM
     if you use the backplane stacking modules with stacking cables you will not need to connect them via copper ports.
  • 3.  RE: Do two stacked 2930M pass VLANS without connecting them from the front side?
    MVP GURU
    Posted Mar 07, 2019 08:00 AM
    ...and you will not need to do trunking for VLANs to pass between the 2 switches...that's exactly because your two Aruba 2930M switches once backplane stacked will become one single logical entity.
