Wired Intelligent Edge
last person joined: 5 hours ago
Does 01 Moxa EDS-508A Series switch works fine with 01 Aruba 1930 switch?
  • 1.  Does 01 Moxa EDS-508A Series switch works fine with 01 Aruba 1930 switch?
    Posted Feb 17, 2023 08:30 PM
    Hi guys,
    Please, Can 01 Moxa EDS-508A Series switch and 01 Aruba 1930 24G 4 SFP/SFP+ switch connect and work fine?
    Best regards.
    Luis Flores
  • 2.  RE: Does 01 Moxa EDS-508A Series switch works fine with 01 Aruba 1930 switch?
    Posted Feb 18, 2023 03:46 AM
    Hi Luis,
    Both are Ethernet switches, so they should interoperate fine. The Moxa switch operates on 10/100 Mbps only, but 1930 24G 4 SFP/SFP+ also supports those modes on its copper ports:
    24 RJ-45 autosensing 10/100/1000 ports (IEEE 802.3 Type 10BASE-T, IEEE 802.3u Type 100BASETX, IEEE 802.3ab Type 1000BASE-T); Duplex: 10BASE-T/100BASE-TX: half or full; 1000BASE-T: full only
    You can find the 1930's datasheet here - https://www.hpe.com/psnow/doc/a00098249enw
    Of course some proprietary Moxa protocols like Turbo Ring and Turbo Chain won't interoperate with Aruba, but they may work through Aruba switch if you connect two Moxa switches to Aruba, but that's not guaranteed and and this should be clarified with Moxa, it all depends on what requirements they have. But if you don't care about those protocols and just need a simple connection between Moxa and Aruba, the short answer is 'it will work'
    Ivan Bondar
  • 3.  RE: Does 01 Moxa EDS-508A Series switch works fine with 01 Aruba 1930 switch?
    Posted Feb 18, 2023 12:01 PM
    I only want connect both switches by VLANs, UTP categoria 6 and a distance de 5 meters. Thanks a lot, Luis. Best regards.
    Luis Flores
