does 3000 serous controller support AOS 6.4 ?
  • 1.  does 3000 serous controller support AOS 6.4 ?
    Posted Sep 03, 2015 11:25 AM
    does Aruba controller 3000 serius support AOS 6.4 as i need to install AP-103H on 3000 serius controller ?
    Thanks ,
    Ehab
  • 2.  RE: does 3000 serous controller support AOS 6.4 ?
    Posted Sep 03, 2015 11:35 AM
    What is the exact controller model?
    Tim
  • 3.  RE: does 3000 serous controller support AOS 6.4 ?
    MVP
    Posted Sep 04, 2015 03:01 AM
    Yes, but.if it's a 3200 controller you'll need to verify the memory.
    The older (non-XM) models need a memory upgrade before being able to upgrade to 6.3 even.
    If you have a 3200, check http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/How-can-I-tell-if-a-3200-has-been-upgraded-to-1GB-of-memory-or/td-p/96067 for info on how to verify which version you have.
    If you have a 3400 or 3600, you're set to go.
  • 4.  RE: does 3000 serous controller support AOS 6.4 ?
    Posted Sep 04, 2015 05:56 AM
    HI,
    Yes, but only 3200 will not support, 3200 XM, 3400 and 3600 will support. 3200 will need high memory hencewe need 3200XM.
  • 5.  RE: does 3000 serous controller support AOS 6.4 ?
    Posted Sep 06, 2015 03:27 AM
    thanks all  ,
    Ehab
