Trying to find a quick answer if you can tie Airwave into your Central deployment.
Thanks!
No. They are completely separate products/solutions.
Generally you'd bring Instant and MAS into AirWave if you already have it.
Thanks for the quick response! Customer has a mixture of IAPs with Central at remote locations and Controller based at HQ.
You should definitely consider managing your Instant APs in AirWave. It will give you a single pane of glass for monitoring the entire wireless infrastructure.
OK, that would be nice. Central is not needed then? I guess I'm not "up" on what Central does exactly. Thanks!
Correct. Central is a cloud-hosted service that is a great alternative to AirWave when using Instant or Mobility Access Switches.
This is a great thread:
http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/AirWave-vs-Aruba-Central/m-p/189525/
