Does anyone have Comware 5 RADIUS logins working?
  • 1.  Does anyone have Comware 5 RADIUS logins working?
    Posted Oct 27, 2016 01:41 PM
    We have Clearpass 6.6.1 running, I am trying to get admin level login for our switches.
    My first switch I am attempting to get working is 3com branded 4800G running 5.20 Release 2220P07
    What attributes do I need to return?
    Previously we have been using IMC to do RADIUS and I did a packet capture to see what it was sending.
    I see
    Service-Type(6): Login(1)
    Login-Service(15): Unknown(50)
    3Com-User-Access-Level(1): 3Com-Administrator(3)
    3Com-Connect_ID(26): 18268xxx (where xxx so far is a changing number for each connection)
    I tried returning service type login, login-service ssh(50), 3com-user-access-level 3Com-administrator
    and all I see is "access denied" when I enter my user/password
    I do see in the clearpass monitor that it is accepting my user/password and returning
    Radius:3com:3Com-User-Access-Level3
    Radius:IETF:Login-Service50
    Radius:IETF:Service-Type1
    So my best guess is I need to use a different attribute to log in?  Hopefully, someone has done this and has it working.
    My switch is configured like this:
    radius scheme Clearpass
    server-type standard
    primary authentication x.x.x.x
    primary accounting x.x.x.x
    key authentication xxxxxxx
    key accounting xxxxxxxx
    user-name-format without-domain
    domain radius
    authentication login radius-scheme Clearpass local
    accounting login radius-scheme Clearpass local
    authorization login radius-scheme clearpass local
    access-limit disable
    state active
    idle-cut disable
    self-service-url disable
  • 2.  RE: Does anyone have Comware 5 RADIUS logins working?
    Posted Oct 27, 2016 03:51 PM
    To provide further detail. I see my packets from clearpass coming in as "Access-Reject" where I would see "Access-Accept" from IMC.
    Not sure why it is transmitting as a reject.
    This is actually not true. I didn't realize I got several access-accept from clearpass prior in the same "conversation"
    clearpass.PNGI am not a smart man. Forgot to add "domain default enable Clearpass" to my config I had it set to another test. And server-type should be extended
