Does anyone know what the differency is between Authentication InnerMethod and OuterMethod?
  • 1.  Does anyone know what the differency is between Authentication InnerMethod and OuterMethod?
    Posted Sep 18, 2015 05:00 PM
    In CPPM, I used AD credentials for 802.1X authentication. I noticed my 'Authentication: InnerMethod' is EAP-MSCHAP2 and my 'Authentication: OutterMethod' is EAP-PEAP. What does this mean?
    Thank you!
  • 2.  RE: Does anyone know what the differency is between Authentication InnerMethod and OuterMethod?
    Posted Sep 18, 2015 05:01 PM
    Outer method can be an anonymous identity outside the tunnel and inner is the real identity that gets check against the authentication server.
    Tim
  • 3.  RE: Does anyone know what the differency is between Authentication InnerMethod and OuterMethod?
    Posted Sep 18, 2015 05:08 PM
    Thank you for your reply!
    Do you know any document explaining this with details?
  • 4.  RE: Does anyone know what the differency is between Authentication InnerMethod and OuterMethod?
    Posted Sep 18, 2015 05:10 PM
    It's part of the EAP RFCs. You'll find plenty of information there.
    Tim
