Does anyone use AirPcap to capture packets on the WIFI side using Wireshark?
  • 1.  Does anyone use AirPcap to capture packets on the WIFI side using Wireshark?
    Posted Aug 12, 2014 08:01 AM
    I can see the management frames and radio.tap info but I can't see DHCp request packet etc. like you would on a wired trace. Is there something I need to setup in wireshark to do this?
  • 2.  RE: Does anyone use AirPcap to capture packets on the WIFI side using Wireshark?
    Posted Aug 12, 2014 08:03 AM
    You would need to do a capture at the controller after decryption to see this.
  • 3.  RE: Does anyone use AirPcap to capture packets on the WIFI side using Wireshark?
    Posted Aug 12, 2014 08:54 AM
  • 4.  RE: Does anyone use AirPcap to capture packets on the WIFI side using Wireshark?
    Posted Aug 12, 2014 10:25 AM
    If the client is connecting used a PSK then you can enter the key and SSID into wireshark. If you can then capture the initial exchange of the client connecting to the wireless you will be able to see the decrypted traffic.
