does Aruba 2920 support a Critical VLAN for DUR
  • 1.  does Aruba 2920 support a Critical VLAN for DUR
    Posted Sep 17, 2020 05:34 PM
    I am in the process of configuring switches for Downloadable User Roles (DUR) we mostly have 5400R and 2920 series. I was in the process of trying to configure a critical vlan (for when CPPM is unreachable) and I noticed that the 2920 does not have that capability or at least the same command does not work. the command I am attempting to use is:
    aaa port-access <PORT-LIST> critical-auth {voice-vlan <VLAN-ID> | data-vlan <VLAN-ID>
     | user-role <ROLE-NAME>}
    There is no "critical-auth" option on the 2920; however there is on the 5400 series. Does anyone know if the 2920 supports the critical VLAN feature and if so how do I go about configuring it.
    The FW version we are running is 16.10.0007
    Thank You
  • 2.  RE: does Aruba 2920 support a Critical VLAN for DUR
    Posted Sep 17, 2020 07:07 PM
    yes it is supported from 16.08 version
    its something  like this
    aaa authorization user-role name critical-auth-role
    vlan-id tagged 10
    vlan-id untagged 20
    exit
  • 3.  RE: does Aruba 2920 support a Critical VLAN for DUR
    Posted Sep 18, 2020 09:12 AM
    Thank You.
    Is that a global rule, because I thought I had to configure a port to use the critical role by issuing the "aaa port-access" command after issuing the "aaa authorization user-role". I'm getting this information from here: https://techhub.hpe.com/eginfolib/Aruba/16.08/5200-5488/index.html#GUID-14183A41-52DC-474A-B5CA-D1F02B2DB3E7.html
    They really need to update the Wired Policy Enforcement Guide. the most recent version I can find is from 2018.
    I'm working remotely for next few days so I will not be able to test anything until next week.
