Does Aruba 3400 Controller supports the new APs models like IAP207 or IAP 305?
  • 1.  Does Aruba 3400 Controller supports the new APs models like IAP207 or IAP 305?
    Posted Jun 14, 2017 07:13 AM
    I have an old controller 3400, does it support the new APs models like IAP207 or IAP 305?
    If yes what should i do?
  • 2.  RE: Does Aruba 3400 Controller supports the new APs models like IAP207 or IAP 305?
    Posted Jun 14, 2017 09:44 AM
    No.  The minimum ArubaOS version is 6.5.1.0 for the AP-207:  http://www.arubanetworks.com/assets/ds/DS_AP207Series.pdf
    The 3400 does not run anything later than 6.4.x.x
