Does Aruba 650 controller supports AOS 6.4?
  • 1.  Does Aruba 650 controller supports AOS 6.4?
    Posted Oct 21, 2014 09:02 AM
  • 2.  RE: Does Aruba 650 controller supports AOS 6.4?
    Posted Oct 21, 2014 09:12 AM
    Yes but:
  • 3.  RE: Does Aruba 650 controller supports AOS 6.4?
    Posted Oct 21, 2014 09:41 AM
    Great Thanks...
  • 4.  RE: Does Aruba 650 controller supports AOS 6.4?
    Posted Jan 16, 2017 05:02 PM
    hence 205AP "access point" works on 650 controller with 6.4 OS?
  • 5.  RE: Does Aruba 650 controller supports AOS 6.4?
    Posted Feb 26, 2017 11:52 PM
    The minimum OS version to bring up AP-205 is 6.4.1.0.
    If your 650 is running on 6.4.1.0 or higher, AP-205 should work fine.
    http://www.arubanetworks.com/assets/ds/DS_AP200Series.pdf
