Wired Intelligent Edge
Does Aruba 8320 support any nac solution?
  • 1.  Does Aruba 8320 support any nac solution?
    Posted Sep 01, 2019 08:18 AM
    Does Aruba 8320 Switch Series is supported multi vendors NAC like:
    Thanks you!
  • 2.  RE: Does Aruba 8320 support any nac solution?
    Posted Sep 01, 2019 06:10 PM
    You generally don't use NAC on a core or aggregation switch.
  • 3.  RE: Does Aruba 8320 support any nac solution?
    Posted Sep 02, 2019 06:49 AM
    Is this required for a tender?
    Like Tim says: port-access is not common on a core, but the switch does supports radius and tacacs for management. please also see:
    https://www.arubanetworks.com/assets/ds/DS_8320Series.pdf
  • 4.  RE: Does Aruba 8320 support any nac solution?
    Posted Sep 04, 2019 05:14 PM
    Hey,
    Thank you Fabian and Tim!
