Does Aruba Central supports firewall setup?
  • 1.  Does Aruba Central supports firewall setup?
    Posted Sep 24, 2014 06:26 AM
    Hi all!
    I have a question about Cloud subscription.
    Does it allow to setup Firewall rules for SSIDs (Role-based, Network-based, bandwidth contracts, deny access to particular domain, etc) in the same manner Instant does?
    I mean the "Access" tab in SSID "Edit" screen in the instant WEB UI.
    Any reference link? Could not find it in the User guide for Central :(
    Thanks a lot!
  • 2.  RE: Does Aruba Central supports firewall setup?
    Posted Sep 24, 2014 06:28 AM
    Yes, all of those configuration options are there.
    Here's a link to the user guide.
    http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=14523
  • 3.  RE: Does Aruba Central supports firewall setup?
    Posted Sep 24, 2014 06:48 AM
    Thanks a lot!
    For applications, this is on the page 53-56.
