Does Aruba controller-based AP support auto firmware upgrade?
This thread has been viewed 21 times
  • 1.  Does Aruba controller-based AP support auto firmware upgrade?
    Posted Apr 19, 2021 10:05 PM
    Hi, does Aruba controller-based AP support auto firmware upgrade?
    Thank you.
    Wei Kwong Ong
  • 2.  RE: Does Aruba controller-based AP support auto firmware upgrade?
    Posted Apr 20, 2021 10:27 AM
    Hi Wei,
    Sure, when you upgrade the controller the APs will download the firmware from the controller and reboot. Both controller and APs must have the same firmware version to work properly.
    Julian
  • 3.  RE: Does Aruba controller-based AP support auto firmware upgrade?
    Posted Apr 21, 2021 02:25 AM
    Moreover, in a redundant environment you can perform a "hitless upgrade" if things are set up correctly.  I've used it in a 24/7 environment, and it works well.
    Further, if you have a virtual Mobility Master, there is no cost to set up a redundant VM for failover purposes.  You would, however, need redundant virtual Managed Devices.
    Timothy Leadbetter
    ACMP, ACSP, ACCA
    CWNA, CWDP
    ECSE-Design
