Hi all, does Aruba CX 6400 support fail-open?
Thank you!
you mean for CX6400 ports can be configured with fail-open for authentication of ports?
https://community.arubanetworks.com/t5/Security/unauthorized-users-have-network-access-due-to-switch-fail-open/td-p/292822
can you little bit elaborate your requirement?
Best Regards,
Suresh
Hi Suresh,
Yes, what i meant is Aruba CX 6400 ports can be configured with fail-open for Open Authentication Role or not? Open Authentication Role is supported by Aruba 5400R based on the data sheet.
