Does aruba has zero configuration APs..
  • 1.  Does aruba has zero configuration APs..
    Posted Sep 19, 2013 02:43 AM
     can we power on AP and let it configure itself?
  • 2.  RE: Does aruba has zero configuration APs..
    Posted Sep 19, 2013 03:13 AM
    Yes. It is called Aruba Activate.
    Please have a look at: http://www.arubanetworks.com/pdf/products/FS_Activate.pdf
    HTH,
    -Thomas
  • 3.  RE: Does aruba has zero configuration APs..
    Posted Sep 19, 2013 07:29 AM
    The APs that support this are Instant APs...no Campus APs already existing can support this activate method.  In terms of Instant, you can order them from the factory and convert them to Campus APs and note that some RAPs are sent out now as Instant APs (RAP3 and 155).
    I guess a bit more info is needed to understand what you actually need and want
